306 gti6 brake help
went to fit my gti6 set up today and the carriers touch the hub and don't line up and seem to small for the new discs
cars a 2004 2.0hdi
Thats strange, i have gti6 brakes on my berlingo and fit no bother at all. everything is interchangeable so should go straight on. Can you get some pics of the problem your having? To me is sounds like the same problem you get when you fit gti6 brakes on a 106, you have to grind down a bit of the caliper so it doesn't hit the hub
That's what I was thinking the berlingo one has a bend and the 306 one is flat. I'll take some pics tomorrow I put the original stuff back on so I could get the car moved
Must be the same setup as like on a 106, you will have to grind away a little bit of the carrier, don't worry about it, it won't affect the brakes at all. Done it plenty of times myself. Got to take a good bit off it tho, just keep taking abit off and trying it, you will get there
I'll have a bash at it today and see if I can sort it. If not I've got a full set up for sale
How did you get on? Did you get them fitted?
got side tracked just relised the wifes jimny needs mot this week. going to have a go at it tomorrow
do you think it makes a difference what year the berlingo is and what gti calipers you use
No mate, most Peugeot/Citroen parts are interchangeable, fitted a set of gti180 brakes on my mates 2008 Berlingo a few weeks back what's the same as gti6 brakes really.
Here's my gti6 brakes on my 52 plate
[Image: F0CA6550-92BE-413F-A2DB-2FF99A770426_zps2pv9frcx.jpg]
just weird how some seem to fit and mine need grinded lol
do you have a pic of the numbers on the caliper
No pics of the number but if you'd is the 106 style hub & strut it will need grounded to fit where mine is the 306 hub setup
Side Light Bulb Holder
14-01-2026 07:58 PM
ASDA AdBlue 10 January 2026
13-01-2026 07:04 AM
Last Post: andy@andymcm.com
12-01-2026 01:47 PM
» Replies: 24
Sticky throttle
Last Post: knucklerash
11-01-2026 05:53 PM
10-01-2026 07:54 PM
Last Post: jippo
10-01-2026 05:39 PM
Fuel cooler and hoses
08-01-2026 08:00 PM
Last Post: uk_friendly_fire
07-01-2026 06:51 PM
» Replies: 37
06-01-2026 10:38 AM
05-01-2026 06:05 PM
