28-02-2016, 04:59 PM
Hi all having a slight issue with the drivers side window not working I have eliminated the following
1. Checked Fuse
2. swapped over switches passenger side still works
3. Removed Regulator and plugged into passenger side it worked
4. Removed Passenger side Regulator plugged into drivers side no power
5. tested voltage to wiring loom it has power when switch is pressed
after looking around google it could be a BSI fault and requires a reset I have tried that and still no joy
any help would be much appreciated
1. Checked Fuse
