Dash message,filter at risk of clogging
In Diesel 1.6 MultiSpace-getting this dash message intermittently. Dealer says it could be the result of lots of short journeys(possible) and first I should boot it a bit for a few miles in third gear at high revs. Any comments on this advice.
What year? If it's an HDi with a particle filter then yes it probably needs a good run. 25 miles at 70-75 (not sure what the speed limits are in the UK).
(29-02-2016, 02:24 PM)lakeside Wrote:  In Diesel 1.6 MultiSpace-getting this dash message intermittently. Dealer says could be result of lots of short journeys(possible) and first I should boot it a bit few miles in third gear at high revs. Any comments on this advice.
Yes. Good run low gear high revs for 20 -30 mins usually sorts them.
Malcolm.
2001 1.9D Multispace.
Just give it a run up the motorway using it normally - at 70mph you will be doing 2600 rpm or there abouts anyway which is more than enough to regenerate the DPF. It should regenerate at 60mph which is about 2200rpm also. Obviously, the longer you drive it the more beneficial it will be to the DPF. I never see the point in doing 70mph in fourth gear to clear a DPF - it's just beating up the gearbox.
[-] The following 3 users say Thank You to Tree for this post:
  • lakeside, ron, Shawks
Thanks for the info, the vehicle is 2013.
Today 08:32 AM
Today 08:16 AM
03-03-2026 06:17 PM
03-03-2026 05:08 PM
03-03-2026 07:57 AM
02-03-2026 02:51 PM
02-03-2026 02:14 PM
Amdro boot jump for sale
Last Post: YTC1
28-02-2026 09:48 PM
Last Post: Muppets on Mars
27-02-2026 01:57 PM
26-02-2026 07:20 PM
