Radiator fans stay on and kill battery
Hi guys, really hoping somebody will be able to help out with this.
I have an intermittent issue where the radiator fan stays on after the engine in off.
Now I know they can stay on for 5/10 mins to do whatever but last November they stayed on and killed the battery... At the time the garage & the AA said I needed a new battery so I had a heavy duty one fitted and the problem was sorted.
Last night when I got home I noticed the fans were still on 20mins or so after I'd got home and the car was on the drive - so I wasn't surprised to find a flat battery this morning.
I've a 59 plate XTR, 1.6d.
Any thoughts as the garage that are normally great are saying they'll simply have to have it in for 'testing' and that they have no idea what it could be...
Thanks, David
Mine stay on occasionally, apparently its cooling the engine bay down after a DPF regen
Did they go off after 20 mins or stay on longer?
Do they come on when driving even when the engine is cold?
They come on fairly quickly when I start the car and no they stayed on longer than 20 mins.
(04-03-2016, 04:34 PM)stumpie Wrote:  They come on fairly quickly when I start the car and no they stayed on longer than 20 mins.
Is their a relay for it?? Maybe that's sticking open..
Okay it sounds like a faulty temperature sender if you get a diag done i suspect it will show this.
(04-03-2016, 04:44 PM)polar Wrote:  Okay it sounds like a faulty temperature sender if you get a diag done i suspect it will show this.
Thanks Polar. I started reading on it and you can't help but read the dpf/cat replacement stories that cost £1000+
The car isn't worth much so I have to be honest and say I was thinking perhaps it was time to retire her in favour of a bigger Dispatch Combi...
But a faulty temperature sender sounds less than £100 so I'll give it a go.
Thanks again Wink
Stu always start with the simple stuff first - by the way it wont hurt to pour a bottle of Millers into the tank and give it a good blast to help clean out the DPF.
The last time i replaced a temperature sender to rectify the same problem you have it cost £12.50 for the part
(04-03-2016, 05:02 PM)polar Wrote:  The last time i replaced a temperature sender to rectify the same problem you have it cost £12.50 for the part
Cool beans, thanks.
triangle light
14-06-2026 09:30 PM
13-06-2026 04:32 AM
Last Post: Jed Clampit
12-06-2026 10:44 PM
My Berlingo Multispaces
11-06-2026 05:21 PM
Last Post: ADarkDividedGem
10-06-2026 10:25 AM
08-06-2026 11:13 AM
Last Post: TGD
06-06-2026 09:50 PM
Last Post: CB-K9murph
05-06-2026 05:47 AM
03-06-2026 06:47 PM
Fuel pump problems
02-06-2026 07:07 PM
