05-03-2016, 01:20 PM
my seatbelt light is constantly on even though
The buckle is attached. I've disconnected the connection block under the seat and used a voltmeter to check continuity between the two cables going to the stalk. When the buckle is connected there is a open circuit and when disconnected there is a closed circuit. The two cables that come from the floor (1 brown 1g/y) have 12 volts between them. Is this normal? Any ideas where else to check? Thanks for your help
