Threads: 23
Thanks Received: 27 in 24 posts
Thanks Given: 31
4
Driving along this afternoon and there was a noise like you had dropped something down the dash. 10 Mins later I went to hit the brake and felt something on the floor mat and seen this lying on the floor mat.
Anyone know what it is?
[Image: 2016-03-05%2017.18.47_zpshrozwekc.jpg]
[Image: 2016-03-05%2017.19.05_zpstfn4nv20.jpg]
[Image: 2016-03-05%2017.19.25_zpsti5c4xtd.jpg]
Threads: 12
Thanks Received: 386 in 274 posts
Thanks Given: 16
37
It's the pollen filter lid, located upwards above the clutch pedal
The following 1 user says Thank You to Lighty for this post:1 user says Thank You to Lighty for this post
• ron
Threads: 23
Thanks Given: 31
4
(05-03-2016, 05:37 PM)Lighty Wrote: It's the pollen filter lid, located upwards above the clutch pedal
Do I need to take the cover above the pedals off to access that?
Couldn't see anything when I had a quick look but its chucking hail/rain at the moment.
Threads: 5
Thanks Received: 131 in 115 posts
Thanks Given: 3
19
Citroen optional extra ice cube tray
The following 2 users say Thank You to Col for this post:2 users say Thank You to Col for this post
• doofer, Hughzie
Threads: 23
Thanks Given: 31
4
10-03-2016, 11:26 PM
(This post was last modified: 10-03-2016, 11:27 PM by Hughzie.)
Well I finally got it back on, What a pain in the arse place to put it!
The pollen filter was changed when it was in for its service, Hence why it fell off. I have since spoken to the garage (About my other vehicle, but mentioned it in the conversation) and the guy said it was a design feature Citroen came up with, Put the pollen filter on the passenger side to make it easy to access, only they never reversed the location for the Right hand drive market.
Threads: 23
Thanks Given: 31
4
(11-03-2016, 02:17 PM)doofer Wrote: It's completely potty, but it works.
I've wondered why the glovebox is so small, given that almost everything that should be behind it is stuffed behind the steering wheel instead.
Do they leave a big empty space where the pollen filter and blower would be (behind the glovebox) on a LHD version? Perhaps they just don't want to make the UK version better than the French one.
Im guessing the LHD has a proper sized glove box as theres load of room on the right.
Can barely fit a tape and torch in the RHD glove box.
Nope, on my LHD the glovebox is tiny as well
Threads: 27
Thanks Given: 20
13
The clue is in the name, room for one glove :-)
