Thanks Received: 69 in 66 posts
Thanks Given: 8
5
Maybe starter wearing out.this how mine started.took a few turns in the morn.then fine all day.put new starter on.then was fine...
Threads: 67
Thanks Given: 237
50
First start of the day then every other start during the day is ok ? Which engine are you referring to ???
Serieal Berlingo owner
Threads: 43
Thanks Received: 416 in 373 posts
Thanks Given: 137
33
Could be the glow plugs needing looked at
Threads: 9
Thanks Received: 26 in 21 posts
Thanks Given: 19
If it's the 2.0HDi don't waste money on diagnostics or other stuff like glow plugs - replace the starter motor with a new one, there's a high power one on ebay for about £69. It will resolve your issue like it has done for me and countless other people.
Threads: 9
Thanks Given: 19
The HDI engines will start without the glow plugs easily, even in minus temperatures.
Threads: 20
Thanks Given: 7
15
(06-03-2016, 08:41 PM)Growler73 Wrote: The HDI engines will start without the glow plugs easily, even in minus temperatures.
So true is that. I've not looked but so far as I am aware, the 112bhp variant found in the C4 Picasso doesn't even have glow plugs. If it does, I've certainly never seen the symbol for it on cold mornings. Just turn the key and it fires immediately.
Threads: 43
Thanks Received: 42 in 37 posts
Thanks Given: 3
07-03-2016, 07:55 PM
(This post was last modified: 07-03-2016, 07:56 PM by landcrab.)
glow plugs on a 2.0 hdi dont light until -2deg . as said fit a heavy duty starter . been there and done it.
Threads: 27
Thanks Given: 20
13
Basics first, is the battery in first class condition, have it load tested before assuming it is ok.
