Electrical Issue (Partner)
Hi,
I have a 2003 1.9 Partner and recently the battery light has started to come on whilst driving (not all the time tho), sometimes it just turns off again but it always turns off when the engine is restarted.
I have checked the voltage whilst idling/revving and all appears ok which leads me to believe the alternator is fine. The van has never had an issue starting tho.
There is a single small wire which goes onto the alternator (guessing for the sensor) and this seemed pretty corroded so replaced the connector but this doesn't seem to have made any difference.
There are a couple of other issues but I not sure if they are related or not, the horn only works with the ignition off and when the battery light comes on the stereo (aftermarket) switches off.
The rest of the electrics appear fine tho!
If anyone has any ideas I would be grateful.
Hi burtross your horn issue is probably the earth on the steering wheel under the airbag. Ive had to do both of my berlingos to sort it. There is a thread on here with pictures to show you how to do it have a search. Here you go http://www.berlingoforum.co.uk/thread-36...l#pid26651 have a look at post 12. Thanks to Geoff for the post. As for the other faults start with the basics check battery is good and good connections, same with alternator check contacts/wiring and output. You should be getting about 14 volts when engine running Check earth leads from battery and engine to chassis.
Rattling calipers
Yesterday 05:36 PM
eolys
Last Post: magoo1
15-05-2026 06:02 PM
Yet another ABS fault
13-05-2026 05:57 PM
Mileage
Last Post: Taffy747
11-05-2026 11:51 AM
11-05-2026 09:17 AM
03-05-2026 01:27 PM
Head unit quad lock
03-05-2026 11:17 AM
Spare Key Fob?
29-04-2026 08:05 PM
29-04-2026 06:27 PM
Eolys problem
24-04-2026 07:07 PM
