[Warning Light] Multiple dash lights on
Hello all, am new to the forum as have recently aquired a 2004 berlingo van, its a 1.9 dw8. Bought it as a non runner and have replaced the engine due to it having multiple problems and decided it wasnt worth messing about with. Having replaced the engine and got it running after de arming the fuel pump and replacing the stop solenoid all is good. The problems i am now faced with are electrical. I have the air bag light on, oil pressure light on and what looks like a traction control light on (yellow triangle with some squiggly lines). Oil pressure is fine and have replaced the sensor. Have removed the plugs under driver seat and soldered wires to try and cure air bag fault and when you shut the drivers door the traction control light goes out, am at a loss now and was looking for some advice, am thinking about an earth fault but am not sure. oh and the radio isnt working, shows the station in centre display but no sound. Any help or advice would be greatly appreciated
(14-03-2016, 10:53 PM)Dennis mackinder Wrote:  Hello all, am new to the forum as have recently aquired a 2004 berlingo van, its a 1.9 dw8. Bought it as a non runner and have replaced the engine due to it having multiple problems and decided it wasnt worth messing about with. Having replaced the engine and got it running after de arming the fuel pump and replacing the stop solenoid all is good. The problems i am now faced with are electrical. I have the air bag light on, oil pressure light on and what looks like a traction control light on (yellow triangle with some squiggly lines). Oil pressure is fine and have replaced the sensor. Have removed the plugs under driver seat and soldered wires to try and cure air bag fault and when you shut the drivers door the traction control light goes out, am at a loss now and was looking for some advice, am thinking about an earth fault but am not sure. oh and the radio isnt working, shows the station in centre display but no sound. Any help or advice would be greatly appreciated
Plug in lexia and read out codes then post them on forum.
Best regards,
brajomobil
Looks like I will have to take it to a garage, was trying to do as much as possible myself before taking it in to get sorted and get an mot at same time
Try doing a BSI reset if you haven't already, if you connected the battery up with electrical systems turned on ie interior light, radio and heater blower the system throws a fit and all manner of things light up. Search on the forum for the correct procedure or just google it. There is a load of earthing points down behind the nearside headlight check these are ok. Is the radio the factory one or aftermarket.
Here you go http://www.petercoopercarrepairs.co.uk/p...cedure.htm
If you haven't got central locking just skip that bit.
Have tried a bsi reset but will do it again to make sure. Yes the radio is a factory fit, scans through looking for stations but can't find any, was wondering if it could be connected to any of the other problems
Have you checked the aerial is plugged into the back of the radio ive lost count of the amount of cars ive picked up and they have just stuck the radio back in and aint bothered with connections as they are moving it on. The aerial co axial goes up the offside pillar I think to the aerial in centre of the roof. Check the bolt fitting as water gets in there and corrodes the wiring. If its got a short whip on to they are crap for signal reception.
Have checked the plugs and connections at the back of radio but not been up top yet, will have a look tonight. I just thought I would of got some static noise coming through the speakers but maybe not
Have been back out at van tonight, when putting the lights on full beam the coolant warning light comes on and another light above it, it ain't looking good
Try disconnecting your radio,I know it sounds daft but I fitted a after market radio in mine all was OK till I turned ignition off,then all hell broke lose,all dash lights came on with fuel gage flashing,and had the keys in my hand?? So took radio out then all back to normal??,so no radio for me..
Diagbox 7.57 download
Today 09:13 PM
Today 05:26 PM
Air filter box removal
Last Post: Harrythephot
Yesterday 11:03 PM
Berlingo undertray
Yesterday 08:56 PM
» Replies: 23
06-03-2026 10:10 PM
» Replies: 21
06-03-2026 04:25 PM
06-03-2026 07:07 AM
05-03-2026 08:16 AM
03-03-2026 06:17 PM
03-03-2026 07:57 AM
