New guy
Well hello folks new to the forum just got myself a wee berlingo van needs a few things rear axle and backbox and wee fiddly bits my first thing is it struggles to start when cold but we'll fire straight away when jump started
2002 zombie van
2.0 hdi 90
Cool
Anyone?
2002 zombie van
2.0 hdi 90
Cool
(19-03-2016, 05:30 PM)Stitches Wrote:  Anyone?
Welcome ,
It you tell us a wee bit more about the van , ie engine size ? and fuel ? age . help will come
 There are a lot different ones and they all have their little quirks .   The starter on some get lazy with age , could be your problem .
If it will start / fire straight away from cold when jump started then your battery would appear to be on its last legs.
However do check the battery terminal posts for corrosion first before going too far though as the jump leads will bypass any bad connections here and give the illusion of a poor battery.
Before spending measure the battery voltage / get it checked at a garage ( free )
By the way welcome to the Forum you should get plenty of help though not everyone is on-line all the time.
Hello Stitches welcome to the forum good to have you with us Smile as the other's have said more info please we can help.
Also look at starter motor,common problem cold starting,I got a recon axle from Im axles £300 deliverd spot on,
Hi guys thanks for the reply it's a 2002 not the face lift one in it is 2.0 hdi the voltage on the battery is 11.79
2002 zombie van
2.0 hdi 90
Cool
11.79 volts **
Also got it running and checked the voltage it's sitting at 14.25volts so am I right saying the alternator is fine doesn't drop below 14 when I turn everything on
2002 zombie van
2.0 hdi 90
Cool
Your alternator looks to be fine.
Look here for useful battery and charging system check / testing / parasitic drain etc etc
http://www.w8ji.com/battery_and_charging_system.htm
If you scroll down you will see the chart for relative charge of the battery / condition
Your battery is either down on charge and needs charging up or is incapable of holding a charge and is dead.
Always indulge in a diagnostic check before spending money, most checks can be done t home for free.
Done all the tests and the draw test battery is definitely goosed thanks for the help guys
2002 zombie van
2.0 hdi 90
Cool
Last Post: BigVtwin996
Today 12:10 PM
Eolys replacement tank
Last Post: jw4821
Today 11:40 AM
Warranty on parts
07-08-2026 04:17 PM
Ahh bless them...
06-08-2026 02:28 PM
06-08-2026 07:34 AM
06-08-2026 01:45 AM
05-08-2026 09:15 PM
Strange whining noise
05-08-2026 04:28 PM
Check this one out guys
04-08-2026 10:01 PM
04-08-2026 11:30 AM
