Rev counter and wiper problem
Ok so after out tinkering on the berlingo Ive noticed my rev counter does not work and the wipers don't work but the washers do can anyone point me in the right direction also I've checked the arms and motor haven't ceased
2002 zombie van
2.0 hdi 90
Cool
Are all the fuses good ??
When you say you have been tinkering did you do anything to the electrics or disconnect the battery? If you don't reconnect in the correct way the electrics throw a fit. Is the battery flat?
All fuses are good I do have a dodgy battery getting a new one the battery had disconnected could a new battery solve this
2002 zombie van
2.0 hdi 90
Cool
If you have low voltage yes it can cause problems. When you disconnect and connect the battery you must follow the correct procedure or it will throw a fit. Read up about BSI reset on the forum.
  • Stitches
Great thanks for the help
I read on how to reset the bsi but I don't have central locking key can i still reset it
2002 zombie van
2.0 hdi 90
Cool
Yes just skip that bit on the " to do list " ..............
Just skip over that part of the reset and you will be fine. But make sure you have a decent battery on to start with.
Cheers guy also am in need of a rear axle had a read about but iam wondering what axles are compatible ie 206 rear or saxo
2002 zombie van
2.0 hdi 90
Cool
Bump...
2002 zombie van
2.0 hdi 90
Cool
Today 10:53 AM
2011 B9 DPF warning light
Today 10:36 AM
Frequent DPF REGEN's
Yesterday 08:43 PM
Power Steering gone - reservoir full, hoses and ...
Last Post: Collapsedsuspension
Yesterday 02:29 PM
Power flex anti roll bar bushes
Last Post: NANO_Vigo
Yesterday 10:54 AM
Power flex lower wishbone bushes
Last Post: AD246
Yesterday 08:54 AM
How to change your username
Last Post: Mike
16-01-2025 11:04 PM
Spot the Berlingo(s)
16-01-2025 12:20 AM
knocking from rear
15-01-2025 04:59 PM
Last Post: Andhall
15-01-2025 04:59 PM
