Threads: 43
Thanks Received: 415 in 372 posts
Thanks Given: 137
33
Pump the fuel primer beside the filter housing until hard, if it starts check the seal round the top of the fuel filter.
Threads: 9
Thanks Given: 316
15
As above ^^
I do know of a few who have modded the fuel line by putting in a non-return valve.
• marchy
Thanks Received: 69 in 66 posts
Thanks Given: 8
5
Go easy with easy start,the engine will start to relay on it,had a old transit like that,it got additited to easy start..
The following 1 user says Thank You to Johny555 for this post:1 user says Thank You to Johny555 for this post
• marchy
Threads: 20
Thanks Given: 2,126
18
Make sure the lid is not cracked.I've seen several that are & let air into the housing,allowing drain back.
Strawberry flavoured windows
The following 1 user says Thank You to ron for this post:1 user says Thank You to ron for this post
• marchy
