Threads: 9
Thanks Given: 316
15
Do it yourself its well worth it
• Alan60
Threads: 22
Thanks Received: 36 in 31 posts
Thanks Given: 8
(22-03-2016, 01:05 AM)polar Wrote: Do it yourself its well worth it
+1.
Malcolm.
2001 1.9D Multispace.
The following 1 user says Thank You to malgpz900 for this post:1 user says Thank You to malgpz900 for this post
• Alan60
Threads: 12
Thanks Received: 18 in 16 posts
Thanks Given: 14
6
do it yourself.
best to try and cover the exhaust with something whilst you do it as it takes a while to burn off any spillage. (and it stinks)
I also own a 22 year old isuzu trooper that when i bought it 15 years ago got the underside waxoyled and the chassis is still like new.
if you keep the car for as long as i have kept my trooper you will need to apply a coating every few years.
also if you have alloy wheels be sure not to get any on them.
The following 1 user says Thank You to dieselj for this post:1 user says Thank You to dieselj for this post
• Alan60
Threads: 22
Thanks Given: 8
Get the black waxoyl is your doing underneath.
• Alan60
Threads: 2
Thanks Given: 7
Many thanks for the replies one and all, much appreciated. Will purchase the black waxoyl for underneath plus the clear/cream coloured waxoyl for other areas some as inside cross members and inside doors and any where else.
I seem to remember having to warm up the wax in the tin by standing it in a bucket of hot water to allow the wax to spray more evenly.
Will spend a good day pressure washing and scraping years of grime and crud off it first.......
Threads: 2
Thanks Given: 7
Polar, that's noted thank you. Never hear of it but will take a look at it. :-)
Threads: 20
Thanks Given: 2,126
18
I've used Waxoyl for 40+ years as a Self employed mechanic.Tips:- Don't do it on a wet/damp car,it can chase water into crevices.Thin to squirt into seams with an oil can.Warm weather is better to aid creep.Remove mud etc or it will act like a sponge.Treat heavy wear areas with Underseal mixed with Waxoyl over already treated body work.In warm weather allow 2hrs min between applications & remember,what runs off doesn't treat the metal.Several light appplications are better than 1 heavy one.
Strawberry flavoured windows
The following 1 user says Thank You to ron for this post:1 user says Thank You to ron for this post
• Alan60
Threads: 2
Thanks Given: 7
Ron, that's great advice, thank you. Have looked underneath the van today and mud is caked all over the chassis and component parts. Will spend time cleaning, rubbing and scraping before treating. Agreed, it has to be worth treating the chassis and giving the van some TLC for once in its life............
