Using my trolly jack
Hi everyone, as a newby I need to ask my quota of daft questions.  Now that I have been a 56 Multispace 1.6 petrol owner for all of five or so weeks Im preparing to start home servicing.
I've read that to lift the front with my trolly jack I should (with timber protection) place the jack under the centre of the front sub frame and for the rear, centre of the tubular axle carrier. Is this correct ?
I have axle stands for safety and support at the scissor jack points.
Thanks......
Hi you can place it under the sub frame but i would not do it in the center i would do it nearside or offside under the sub frame mounting bolts. You can also jack under the sills on the strengthened parts / scissor jack points - you will see clearly where.
At the rear i would not go in the centre but nearside and offside for stability.
  • divingdad
(24-03-2016, 03:51 PM)polar Wrote:  Hi you can place it under the sub frame but i would not do it in the center i would do it nearside or offside under the sub frame mounting bolts. You can also jack under the sills on the strengthened parts / scissor jack points - you will see clearly where.
Thanks for that, I was seeking the reassurance that the sub frame was man enough. I get your point about stability too. Thanks again.
Hi divingdad ?? welcome to the forum Smile why don't you use two trolly jack's you can get another one for about £20 and do as polar said at the jacking point's on both side's so it will be even on the way up and down. Smile
what kind of diving do you do  Tongue Rolleyes Wink
Today 11:03 AM
Last Post: JPCoetzee
Today 10:34 AM
13-03-2026 09:14 PM
13-03-2026 03:21 PM
12-03-2026 03:52 PM
OIL Drip
12-03-2026 01:49 PM
10-03-2026 10:47 PM
10-03-2026 02:49 PM
New owner in Bristol UK
10-03-2026 01:19 PM
Last Post: Alberts elbow
09-03-2026 10:11 PM
