gearbox
my citroen berlingo 1.9 deisel van goes into 5th gear but the stick drops bak to the nutural position any ideas ??
5th gear detent?
(25-03-2016, 07:57 PM)Col Wrote:  5th gear detent?
what do u mean
Does it stay in 5th when then stick goes back? A detent is a spring loaded ball in the selector shafts & hold the selected gear in place as well as preventing 2 gears to be selected at once.HTH
(25-03-2016, 10:01 PM)ron Wrote:  Does it stay in 5th when then stick goes back? A detent is a spring loaded ball in the selector shafts & hold the selected gear in place as well as preventing 2 gears to be selected at once.HTH
yes it stays in 5th gear no problem and comes bak out easy to
You weren't clear that it was staying in gear. It sounded like it was dropping out hence Detent. As it's staying in gear more likely something in the linkage
(26-03-2016, 02:54 PM)Col Wrote:  You weren't clear that it was staying in gear. It sounded like it was dropping out hence Detent. As it's staying in gear more likely something in the linkage
ok thank you ill get it checked is that an easy fix ?
Once you find the loose parts, it's not too bad.
Get someone to run through the gears while you observe what's happening with the linkage.
(26-03-2016, 06:27 PM)Col Wrote:  Once you find the loose parts, it's not too bad.
ok thnx for your help ill let u no how it goes
Today 12:29 PM
Yesterday 07:46 PM
Last Post: CB-K9murph
Yesterday 05:47 AM
03-06-2026 06:47 PM
Fuel pump problems
02-06-2026 07:07 PM
Last Post: Desdinova
27-05-2026 10:15 AM
Last Post: Stevie3393
25-05-2026 12:34 PM
24-05-2026 12:57 PM
Rattling calipers
Last Post: Chrisfox1975
24-05-2026 10:47 AM
Mark 3 camper van conversion
Last Post: minkybeau
23-05-2026 07:38 AM
