COOLANT FLUSH ADVICE
Hi All
thinking about flushing the cooling system, I had a look on the forum but there appears no information
I have identified the following so far, PSA part 9735k4 for 1liter and 9735k0 for 5liter.
Has anyone sourced/indentifed an alternative after market that is the same specification
Can anyone who has flushed the system on a B9 let me know
1: the coolant capacity
2: where in the owner manual is the correct type of coolant listed for a 1.6HDI engine
3: the flushing procedure and is there a bleed valve for the trapped air
4: is there a release valve on the radiator or which pipe is the easiest to remove
Thanks in advance
Does the coolant ever need changing? It's not in the service schedule & mines been main dealer serviced for 7yrs without mention of coolant change.
Should be replaced every 2-3 years unless longlife coolant used
If the coolant is pinky red colour it has a ten year life span .If you are unsure go to Citroen Dealer ask them how long the life should be or your local motor factor and ask them about long life coolant.
(26-03-2016, 05:29 PM)Jed Clampit Wrote:  If the coolant is pinky red colour it has a ten year life span .If you are unsure go to Citroen Dealer ask them how long the life should be or  your local motor factor and ask them about long life coolant.
The red stuff is 5 years,that's what's in mine and on the bottle says replace every 5 years
Today 02:50 PM
Today 02:31 PM
Today 11:22 AM
» Replies: 76
06-10-2026 12:46 PM
06-10-2026 10:00 AM
Last Post: RMSSA
22-09-2026 08:52 AM
