[Transmission] oil seepage
i have gearbox oil seeping from side of gearbox just above the filling plug i seem to have pin holes in this location are they there for a reason as just above them i have encrustation and thats where it seems to be coming from if anyone can help it would be appreciated
Hi, From memory it made of alluminium so you may be getting it's form of "rust" and leaking. Think you need to clean it up well to see properly. There are a variety of metal repair pastes that may help. I assume it's not actually leaking from the drive shaft oil seal?
Griff
Landmark
Ex 1.4 Berlingo Multispace
thanks any idea what the part is called in case i have to purchase one[img][Image: fillplug_zpsq1oppets.jpg][/img] the part thats leaking is in the black thanks
I would have thought that the part would be called the "gearbox end cover". I would buy a new gasket then remove the cover to fully inspect it (esp. the inside surfaces) for holes. It might just be a leaking gasket.
If its leaking where the black line is drawn looks like you need a new one,just nip it into a garage they will tell you
Rattling calipers
Yesterday 05:36 PM
eolys
Last Post: magoo1
15-05-2026 06:02 PM
Yet another ABS fault
13-05-2026 05:57 PM
Mileage
Last Post: Taffy747
11-05-2026 11:51 AM
11-05-2026 09:17 AM
03-05-2026 01:27 PM
Head unit quad lock
03-05-2026 11:17 AM
Spare Key Fob?
29-04-2026 08:05 PM
29-04-2026 06:27 PM
Eolys problem
24-04-2026 07:07 PM
