COOLANT LEVEL
Hi all
Can I ask someone to check the coolant level on their B9 when the engine is cold
Reason for asking is that on mine when the engine is cold the coolant level is on the minimum and wanted to know if this is ok or I am loosing coolant
Reading around appears that the coolant level supposed to be on minimum when cold and want to make sure
Thanks in advance
Sounds right, you need space for it to expand when hot. Mine is barely above the min level when cold and has never been a problem.
Mines always been at max mark when cold. I've topped it up very slightly about 3 times in the last 7yrs. I got a bottle of coolant topup from Cits & still have most of it left. I'd top it up to full mark & keep an eye on it.
(30-03-2016, 08:10 PM)manuk Wrote:  Hi all
Thanks in advanceI
I always thought fill to max when cold and should find it own level if over full. I know when I had a 2006 hdi if water level drops below min you get stop light on and beeping
I always keep my coolant and my engine oil levels halfway between MAX and MIN, and have never had any problems.
triangle light
Yesterday 09:30 PM
13-06-2026 04:32 AM
Last Post: Jed Clampit
12-06-2026 10:44 PM
My Berlingo Multispaces
11-06-2026 05:21 PM
Last Post: ADarkDividedGem
10-06-2026 10:25 AM
08-06-2026 11:13 AM
Last Post: TGD
06-06-2026 09:50 PM
Last Post: CB-K9murph
05-06-2026 05:47 AM
03-06-2026 06:47 PM
Fuel pump problems
02-06-2026 07:07 PM
