[Engine] wont start
had it checked getting a fault code p1327.not found anyone yet that knows what that is.its a 1.6 petrol multispace
I checked here and found this:  P1327 Ignition - Integrated Phase detection. But have no idea what it means relating to ignition problems.
Immobiliser issue perhaps??
Are you using the original key?
Looking on another forum, looks like worn plugs or duff coil pack.
When were the plugs last changed?
(01-04-2016, 03:04 PM)tucker Wrote:  Immobiliser issue perhaps??
used original that shows the key symbol spare does not.still wont start
(01-04-2016, 03:07 PM)tucker Wrote:  Looking on another forum, looks like worn plugs or duff coil pack.
plugs and coil pack changed about two years ago
Plugs are overdue a change then.
My 1.6 petrol gets a bit iffy when the plugs are a year old.
I actually have to change them every 6 months as it's LPG and it demands a strong spark. It runs lumpy as soon as they start to deteriorate.
After 2 years they will be well past their best.
You really need to get it on a decent diagnostic machine clear the codes and then see what comes back. When you say you changed the coil pack and plugs 2 years ago how many miles is that?
Just a quick search brought up this on another citroen site https://citroenc3owners.com/petrol-citro...-t542.html
Just a thought did you get a decent make or genuine coil pack as there is a lot of cheap crap out there with the life span of a moth.
If you are using NGK plugs, they can cause this issue under some circumstances
Rattling calipers
Yesterday 05:36 PM
eolys
Last Post: magoo1
15-05-2026 06:02 PM
Yet another ABS fault
13-05-2026 05:57 PM
Mileage
Last Post: Taffy747
11-05-2026 11:51 AM
11-05-2026 09:17 AM
03-05-2026 01:27 PM
Head unit quad lock
03-05-2026 11:17 AM
Spare Key Fob?
29-04-2026 08:05 PM
29-04-2026 06:27 PM
Eolys problem
24-04-2026 07:07 PM
