[Engine] 2.0 HDI engine mount.
Just wondering if this top engine mount is meant to have this sort of gap in it before I order a new one.
I have a little engine slap every now and then whilst just easing off then putting the gas back on.
car is an 4 plate with 95k on the clock.
[Image: 20160402_200153.jpg]
[-] The following 1 user says Thank You to dieselj for this post:
  • malgpz900
Looks fine to me dieselj
  • dieselj
It'll probably be the engine mount down at the back of the engine that's worn. It's not hard or expensive to replace.
[-] The following 1 user says Thank You to Growler73 for this post:
  • dieselj
thanks guys. I will be changing the rear on soon.
just a thought. is there 3 or 4 mounts on the engine?
If you have access to a press, you can just buy the bush for the lower mounting from the dealer, it's about £16 (or was when I did mine 3 years ago)
Yesterday 08:03 AM
Last Post: RMSSA
22-09-2026 08:52 AM
Turbo lag 1.6HDi
Last Post: Westy
21-09-2026 09:07 AM
16-09-2026 09:50 AM
» Replies: 16
removing front strut
16-09-2026 02:07 AM
Strut Top Mounts
15-09-2026 07:58 PM
