Power steering leak
I changed the oil the other day and spotted an area where a leak had spread onto the subframe and surrounding area. I had a good look round and it didn't seem to be oil and concluded it was power steering fluid seeping from somewhere.
I couldn't find where it was coming from, so it must be a seal weaping.
Sure enough the power steering fluid was low. I drained out what I could from the reservoir and fiilled it with some Leak Stop fluid.
It claims to guarantee to stop leaks which seems a bold claim.
Has anyone any experience of using this stuff and having any joy from it?
Haven't used the stuff your talking about but i had a leak on my m59 and it was coming out of where the pinion is located near where it meets the column/uj it was seeping out the top and required a new rack.
I've used the Lucas Stop Leak before. It works for minor weeping but you are only delaying the inevitable.
If I knew where it was coming from I'd probably tackle it but at the minute I haven't a clue.
I cleaned up all the mess yesterday, so hopefully it will be a bit easier to get underneath in a few days and see if it's any more obvious from any new fluid loss.
I think I have identified where the leak is coming from.
It doesn't seem to be the steering rack but the Base of a blue sensor above it. I will try and upload a photo. Does anyone know what the sensor is?
Attached Files Thumbnail(s)
Photo from above of the connector.
Looks to be the power steering pressure sensor.
Appears to be a split in the attachment nut ?
These cost about £20 so a cheap fix.
  • tucker
I had a xsara whic blew the sensor clean off the fluid hit the exhaust and you can picture the rest I would check that it's not cracked
2002 zombie van
2.0 hdi 90
Cool
Ah yes. I hadn't noticed the top nut has a crack. I was thinking it was coming from lower down below the bottom nut somewhere.
Thanks for that.
Does anyone know the process for replacement? Do I need to drain the reservoir?
I'd just arrange containment and slacken the nut to allow a controlled release of the oil then when it stops just swap sensor with new one and fill with new oil.
Today 08:36 AM
» Replies: 15
Yesterday 05:12 PM
04-11-2026 11:37 PM
Last Post: Drantanborg
31-10-2026 03:59 PM
24-10-2026 08:09 PM
