Berlingo Newbie
Hello All,
I am the proud new owner of a 64 plate Multispace XTR Auto, and I have to say how impressed I am with her (my cars apart from a Lada some years ago, are invariably female). I and my wife are newly retired, and for reasons that seemed a good idea at the time have moved from Blackpool to Leeds just over a year ago. We came into Berlingoland after a disastrous year with a campervan. The 'van itself which was Berlingo based was fine but we are not as mobile as we used to be and there simply wasnt enough room for us and the dogs. I noticed that a lot of the taxis round here are Berlingos, which is always a good sign, so here we are.
Having successfully locked myself in the back, by the simple process of climbing in and shutting the door, I have solved the rear childlock issue, which is not very well described in the owners handbook. What is needed is a small cranked screwdriver to get at the rubberised screws on the rear of the back doors near the lock. I would like some advice on the DPF/FAP system. Mine is a 1.6/90PS diesel, so is likely to have one. The handbook says the fluid goes in a blue cap next to the diesel filler. Mine hasnt got one........ Is it user fillable or dealer only or sealed for life ?? Does anyone know ???
Many thanks for any advice.
Richard
PS How do you get a photo on this forum ??
Hi Rick and Bev and welcome to the forum.  Glad to have you with us.  Can't help you with the urea additive as mine predates that "feature".  Posting photos is easy.  When you start a thread there is an icon (a little square with blue centre) on the upper row of icons that says "insert an image" on mouse over.  Click there and insert URL.  Or, you can scroll down the posting area until you see the blue "Attachments" section.  Browse to the image location on your computer and attach it to the post.  Look forward to seeing pix of your ride.
[-] The following 1 user says Thank You to 3rensho for this post:
  • rickandbev16
Many thanks, I will look for that next time I post
Hello rickandbev welcome to the forum good to have you with us Smile I'm sure some one will be along to help you with the Ad blue being a 64 plate it mite be  a Eolys one if you go to the back of the berlingo look under where the fuel tank is you will see a little tank next to the main fuel tank that's where the eolys goes for the regeneration of the DPF/FAP it need's topping up between 80'000 / 100'000 miles make sure you only fill up when you need to has it will add some eloys to the fuel each time you fill up and will run out sooner if you fill up say every half a tank.
  • rickandbev16
(05-04-2016, 09:17 AM)Jed Clampit Wrote:  Hello rickandbev welcome to the forum good to have you with us Smile I'm sure some one will be along to help you with the Ad blue being a 64 plate it mite be  a Eolys one if you go to the back of the berlingo look under where the fuel tank is you will see a little tank next to the main fuel tank that's where the eolys goes for the regeneration of the DPF/FAP it need's topping up between 80'000 / 100'000 miles make sure you only fill up when you need to has it will add some eloys to the fuel each time you fill up and will run out sooner if you fill up say every half a tank.
Sorry what is "EOLYS" ?? . So do you have to top up from underneath car ??
Many thanks, Richard
It's an additive, and yes top up from underneath. It is very unpleasant stuff, so take full safety precautions.
  • rickandbev16
Many thanks for that
Richard
Last Post: ADarkDividedGem
Yesterday 08:06 PM
Yesterday 07:46 PM
Last Post: CB-K9murph
Yesterday 05:47 AM
03-06-2026 06:47 PM
Fuel pump problems
02-06-2026 07:07 PM
Last Post: Desdinova
27-05-2026 10:15 AM
Last Post: Stevie3393
25-05-2026 12:34 PM
24-05-2026 12:57 PM
Rattling calipers
Last Post: Chrisfox1975
24-05-2026 10:47 AM
Mark 3 camper van conversion
Last Post: minkybeau
23-05-2026 07:38 AM
