Threads: 4
Thanks Received: 1 in 1 posts
Thanks Given: 4
Hi all, new to the forum, looking for some advice please. We've just bought a 2013 XTR, absolutely love it . My wife finds the driving seat position a little uncomfortable, she finds that the seat base angle is making her driving position uncomfortable. We have tried different set ups, without success so far. Is there any way to tilt the base forwards ? Has anyone else had this issue ? Any ideas in how to fix this would be great, thank you.
Threads: 4
Thanks Received: 11 in 10 posts
Thanks Given: 1
I had a similar need and solved it by buying a wedge shaped cushion that fits the seat squab. Got it from Aldi I think, but a back specialist shop should do one...
The following 1 user says Thank You to cliffy for this post:1 user says Thank You to cliffy for this post
• Macca79
Threads: 21
Thanks Received: 24 in 21 posts
Thanks Given: 133
I've done 180k with a normal cushion on the seat,it soon moulds to how you need it
Threads: 0
Thanks Received: 14 in 13 posts
Not sure if it's mounted the same as the m49,but I fitted 2 x 1" steel blocks under the rear mounts and replaced the 2 bolts for longer high tensile ones.
Aldi over here in Australia has a set of 2 memory foam chair cushions on sale this week for $29. So I replaced the ones I bought 4 years ago for fresh ones.very comfortable. Our clark rubber stores sell similar product for nearly $100 each cushion!
The following 1 user says Thank You to robfitzi for this post:1 user says Thank You to robfitzi for this post
• Macca79
Threads: 27
Thanks Given: 20
13
Not exactly related to seat height, but does anyone actually find the armrest of any use?
I'm of fairly average build but the armrest seems to be in the totally wrong position and is completely useless.
Threads: 67
Thanks Given: 237
50
I also fitted spacer blocks on my Mk2 van which worked well for many miles / couple of years ( eventually sourced new seats ).
Arm rests - When I changed my van for the car version I was really pleased to have arm rests but then having tried them I found them more pain than the worth of it, my wife as passenger didn't like them also - arm rests removed sharpish.
Serieal Berlingo owner
• Macca79
Threads: 4
Thanks Given: 4
Thanks for the suggestions, I had thought about fitting spacers, although the I wanted to see if anyone else had successfully tried it first. I'm assuming you guys have fitted your spacers under the frame base rather than directly under the seat runners ?
Threads: 0
Yes that's correct to place the spacers under the frame
• Macca79
Threads: 20
Thanks Given: 2,126
18
My last Berlingo had armrests---never used them.
Strawberry flavoured windows
