Threads: 7
Thanks Received: 7 in 7 posts
Thanks Given: 1
Hi Andy,
I too liked the look of the centre console for my old Pug Partner (2012) which had a big gap between the front seat, so I bought one of ebay and then worried how to fit it.
What I found was under the scabby bit of carpet between the seats were a variety of small bolts holding down the plastic thing in this space. I simply removed two of these, got some longer ones out of the parts bin then drilled 2 holes in the bottom of the bin which lined up perfectly and secured the bin to the car - was good enough to last 3 years before I swapped the pug for a bingo, which had said console already fitted. So now I have a spare roll top console in the garage.....
The following 1 user says Thank You to Mr Keef for this post:1 user says Thank You to Mr Keef for this post
• templogin
Threads: 6
Thanks Received: 1 in 1 posts
Thanks Given: 17
Ooh! That's interesting. I will have a look at the car when it lands here.
Threads: 7
Thanks Given: 1
[quote pid='86525' dateline='1460912229']
I've removed mine a few times, when carrying loads especially. The front passenger seat won't fold flat while it's in place as the arm rest hits it. So fixing anything in permanently may be a problem.
[/quote]
Was never a problem in my Pug - the front seat folded forward flat no issues with bin in place, not that was something I did so often(like twice perhaps with some fencing panels) - in 3 years I never had the need to remove it.
Threads: 7
Thanks Given: 1
Just tried it & of course you're perfectly correct, however to remove the armrest is 5 seconds and no tools, so is not a show stopper - depends how often you're going to fold flat the front seat, and whether you want it completely flat.
• doofer
Threads: 13
Thanks Received: 44 in 29 posts
Thanks Given: 29
(18-04-2016, 10:46 AM)doofer Wrote: I didn't even know you could remove the armrest! I learn more every day.
What's the removal technique? I'll have a play later.
I fold mine about every fortnight usually, when it needs to go into van mode.
There's a little button to press on the plastic rim on the seat. If you put the arm rest upright it's on the forward facing edge. You press and the arm rest can be pulled out.
Sent from my SM-T810 using Tapatalk
2013 Berlingo XTR 1.6 HDi 90 (WAV)
2016 Partner Tepee 1.6 Blue HDI S/S (WAV)
2020 VW Caddy Maxi Life 2.0 TDI (WAV)
Threads: 7
Thanks Given: 1
Well done doofer - so bolting down the box ain't such a bad idea after all......
