17-04-2016, 05:17 PM
Could someone more knowledgeable enlighten me please?
As there's only one (brake) fluid reservoir, I presume the same fluid is also used for the clutch? They must be joined?
If this is correct? I presume that I can bleed the clutch cylinder as well? Is it the same process but pressing the clutch rather than the brake?
Thanks in advance?
