18-04-2016, 11:12 AM
Hi everyone,
I've got an intermittent starting fault with my 1.9 Diesel
Yesterday it wouldn't start. It turned over, gave what sounded like two or three cylinders but it didn't "catch".
Gave it a couple of attempts then did a bit of diagnostics. My little scanner said code P1351 which apparently means high voltage on ignition according to this thread (Berlingo P1351 fault thread)
My fault seems different to the problem in that thread so I started a new thread for it.
After waiting a bit I tried clearing the fault and trying again to see if the fault code was persistent. I did stay so it seems a current rather than a past issue.
The engine did start eventually with no additional action.
Today it started no problem. The engine sounded a bit tractor but this may be me being paranoid rather than a different noise to normal. It sounded normal once out of idle.
The Haynes manual doesn't have a lot of trouble shooting but from basics it would seem it can only be a problem in a few things.
Any suggestions welcome.
- Starter motor - but it cranks so maybe not? and by association battery.
- glow plugs - possibility and the P1351 code seems to suggest it is
- fuel supply - but it works fine after starting on motorway.
