[Engine] priming pump leak
Hi, i have had problems with my 2002 berlingo 1.9d just would like to know how much pressure is supposed to build up when priming the system? a small amount of fuel seeps out when pumping and although you can feel pressure build up the pump can still be depressed all the way down. would this cause starting/running problems?
thank you.
If fuel can leak out air can get in causing starting and running problems. As you prime the pump it should get firmer
( this is getting into frankie howard territory now)
  • keifa
have changed the fuel filter housing, primed the system, still will not start for more than a few seconds. then it just turns over and sounds like its backfiring!
Have you primed / bled the main injector pump ? Worth doing as easy and sounds like your issue ( once the leak is sorted of course ).
  • keifa
will find out how to do and then try it tomorrow! Thanks.
Mileage
Today 04:33 PM
eolys
Last Post: magoo1
Yesterday 03:02 PM
Rattling calipers
18-05-2026 05:36 PM
Yet another ABS fault
13-05-2026 05:57 PM
11-05-2026 09:17 AM
03-05-2026 01:27 PM
Head unit quad lock
03-05-2026 11:17 AM
Spare Key Fob?
29-04-2026 08:05 PM
29-04-2026 06:27 PM
Eolys problem
24-04-2026 07:07 PM
