Threads: 10
Thanks Given: 4
I have a question on this part what does it do ? I am looking to fit a boost gauge but don't want to tap into the manifold any info would be great thanks.
2002 zombie van
2.0 hdi 90
Threads: 67
Thanks Given: 237
50
It monitors the inlet manifold vacuum and then varies the turbo boost in response to pressure detected ( I believe ).
Serieal Berlingo owner
Threads: 10
Thanks Given: 4
Thanks any idea on how to go about fitting the boost gauge
2002 zombie van
2.0 hdi 90
Threads: 5
Thanks Received: 131 in 115 posts
Thanks Given: 3
19
Tap into manifold. You could cause problems trying to connect to that solonoid.
Why do you need a boost gauge?
Threads: 10
Thanks Given: 4
22-04-2016, 07:04 PM
(This post was last modified: 22-04-2016, 07:05 PM by Stitches.)
Is that the only way just to make sure it's holding pressure and that
2002 zombie van
2.0 hdi 90
Threads: 5
Thanks Given: 3
19
22-04-2016, 09:06 PM
(This post was last modified: 22-04-2016, 09:06 PM by Col.)
You would know if the turbo was faulty.
Because of the sensitive nature of the controls and sensors, it would be foolish to try and vacuum tap off of the boost control solonoid (or whatever Citroen like to call it) You are likely to screw up it's proper function. You would be better taking a tap off the manifold away from all sother components. Personally, I would'nt bother. It's hardly a race car.
The following 1 user says Thank You to Col for this post:1 user says Thank You to Col for this post
• Stitches
Threads: 10
Thanks Given: 4
Thanks for the info mate think I'll just put back in the shed
2002 zombie van
2.0 hdi 90
Threads: 67
Thanks Given: 237
50
..... Stitches ..... hmmm an interesting name ..... any influence by the film of same name ???
Threads: 23
Thanks Received: 5 in 5 posts
Thanks Given: 2
you can t piece into the pipe on the turbo
