  • 1 Vote(s) - 2 Average
[Warning Light] dim indicator lights
Having just bought a 2007 Desire and enjoying every minute driving it although a few things which I would like to improve
(1) I find that the turning indicator lights (Green Arrows)  on the instrument panel is very dim and very hard to see and the clicking sound is very low
       Is there anyway to improve ether or both ?
(2) The emergency warning switch has the same fault, very hard to see and low sound
The only other fault is the rear window washer is not working although I can hear washer motor working
Any help or advice would be appreciated
I just had to go out and listen to ours as I could not remember if it made a sound Big Grin It does a tick tock noise and the warning lights are fine but it does self cancel so it's not something I worry about. You could fit a trailer type buzzer into the system if you want it to make a noise but the actual flash is controlled by the BSI not a relay which usually supplies the click. You'll have to get your hands dirty to check the rear washer, pull the pipe off somewhere and see if it flows and if it is just the nozzle blocked.
M59 1.4 Petrol question
Yesterday 06:12 PM
Cold Starting
Last Post: jboy012000
18-03-2025 10:46 AM
17-03-2025 08:12 AM
2015 Berlingo van for sale
Last Post: eddyale
16-03-2025 06:47 PM
Last Post: deejay_xb
16-03-2025 02:53 PM
» Replies: 29
2.0 HDI. engine won't start
16-03-2025 01:48 PM
Unusual Braking Problem
16-03-2025 07:52 AM
valeo alternator CL15 rebuild
16-03-2025 07:49 AM
15-03-2025 06:19 PM
oil Sump
15-03-2025 06:18 PM
