Threads: 2
Thanks Received: 2 in 1 posts
Hi,was wondering if anyone has the above mentioned for sale,or tips on making some,or dimensions of Windows.Thx in advance.
Threads: 22
Thanks Received: 36 in 31 posts
Thanks Given: 8
Would it not be easier to measure the size of your own windows, then you can work out how your going to fix them up.
Malcolm.
2001 1.9D Multispace.
Threads: 67
Thanks Given: 237
50
Make a paper / cardboard template and go from there ..... simples
Serieal Berlingo owner
Thanks Given: 188
23
Your best bet is get some large sheets of thin card from an artist shop and use this to make templates of each window. It can be pushed and formed into each curve giving you a final shape to then use to make your final screen/blind from. Ive used this method and used suction cups fixed in the panel to fix to the window.
Are we there yet?????
Threads: 22
Thanks Given: 8
(24-04-2016, 08:14 PM)mogo Wrote: (24-04-2016, 12:42 PM)malgpz900 Wrote: Would it not be easier to measure the size of your own windows, then you can work out how your going to fix them up.
Malcolm.
Have you tried to measure a Berlingo window?They are not symmetrical hence the question.
Don't mean to be impolite but your answer would be just as helpful / pointless if you said."Sorry I don't know."
Was just trying to help.
The final size you decide on will be depend on how you decide to fix them.
Hopefully someone will come up with the measurements you require.
Malcolm.
The following 1 user says Thank You to malgpz900 for this post:1 user says Thank You to malgpz900 for this post
• geoff
Threads: 2
Sorry mate,that reply did sound more ratty than intended,thanx for the input.
