had new radiator fit now no power :s
so I had a new radiator fit and seem to have no power when driving I don't know anything about cars but the pipe on pics had come off front grill will this make a difference [Image: 562898d4e090e199fe8a3655477f057e.jpg][Image: 69fca000b898c6f5c3fa19366174caf5.jpg]
Sent from my SM-G920F using Tapatalk
The pipe is for a cold air feed in to the air filter the engine work's better with cold air if the engine is taking in warm / hot air from the engine bay call heat soak it will not run so efficiently but only by a small amount refit the pipe see how you get on.
attached it no loo. garage has just said seems like head gasket or injector!!!
More info needed here ...............
Was the vehicle running well / normally before the new radiator was fitted ?
Why did you have a new rad fitted ? leaking ? engine over heating ? other reason ?
radiator was leaking iv had it sorted now was a loose connection or something and got it back and now starter motor has gone. no look with this van at all
Warranty on parts
Yesterday 04:17 PM
Ahh bless them...
06-08-2026 02:28 PM
06-08-2026 07:34 AM
06-08-2026 01:45 AM
05-08-2026 09:15 PM
Strange whining noise
05-08-2026 04:28 PM
Check this one out guys
04-08-2026 10:01 PM
04-08-2026 11:30 AM
02-08-2026 02:22 PM
Berlingo 2026
Last Post: xtimex
29-07-2026 03:34 AM
