  • 6 Vote(s) - 2.67 Average
Roof bars HELP .......
Rainbow
Having trouble tightening some citroen roof bars up. got them on e bay and carnt seem to find an allen key that fits. Any advice please.
Replace the Citroen screws/bolts with stainless steel cap headed allen screws and use copperslip to assemble, no more seized in bolts and easy to remove...
(25-09-2011, 04:48 PM)andy-womble Wrote:  Replace the Citroen screws/bolts with stainless steel cap headed allen screws and use copperslip to assemble, no more seized in bolts and easy to remove...
Thanks Andy any idea where i will be able to buy them please....thanks for help.
(25-09-2011, 05:36 PM)David kirton Wrote:  Thanks Andy any idea where i will be able to buy them please....thanks for help.
You need an engineer's or tool merchants or similar also available via fleabay. No use going to Halfrauds... No connections or pecunary interests, but here in Stoke we have a good place called FWB Products, minimum cash sale is £2.00
Cheers managed to get the bolts out tonight so should get some tomorrow ....ta.
(25-09-2011, 03:18 PM)David kirton Wrote:  Having trouble tightening some citroen roof bars up. got them on e bay and carnt seem to find an allen key that fits. Any advice please.
Hi Dave I think the bolts may have a "torx" head. They look like Allen heads. If you have a multi screwdriver bit set you will see them marked T15, T20 and so on. Try these good luck.
PappyConfusedillyme:
If it's the bars on the desire roof, the tool for them is in the drop down cabinet at the back in the boot.
Users browsing this thread: 2 Guest(s)
My Berlingo Multispaces
Yesterday 05:21 PM
Last Post: ADarkDividedGem
10-06-2026 10:25 AM
08-06-2026 11:13 AM
Last Post: TGD
06-06-2026 09:50 PM
Last Post: CB-K9murph
05-06-2026 05:47 AM
03-06-2026 06:47 PM
Fuel pump problems
02-06-2026 07:07 PM
Last Post: Desdinova
27-05-2026 10:15 AM
Last Post: Stevie3393
25-05-2026 12:34 PM
24-05-2026 12:57 PM
