Bump stops 2001 multispace 1.9D
Hi guys I recently bought a 2001 1.9d multispace and it has failed mot on bump stops. Under inspection they are totally decayed. I have bought replacement ones however I am unsure of how to remove old ones any help would be much appreciated. thanks in advance
Sent from my D6603 using Tapatalk
Jack up car
Remove Wheel
Remove lower pinch bolt
Split lower Ball joint and remove from hub
Undo clamping bolt at top of hub
Spread clamp
Undo three top mount bolts
Remove shock absorber/spring complete
Use spring compressors to compress spring
Remove strut top nut
Remove top mount
Remove old bumpstop
Refitting is the reversal of removal
Smile
Hmm it seems I have a different model. There are no springs it is a torsion bar setup and bump stop seems to be just hanging above swinging arm
Ohh sorry thought you meant front ones!
If I remember the just slide into place into the holder on the rear?
Correct fitted in 10 mins thanks
OK so it turns out that the mot fail wasn't due to the bump stops (wasn't very clear on the fail sheet) turns out after retesting it is infact the square axle bushings. Any tips on replacing? Is it a big job?
I'm not sure what the square axle bushings are. Do your rear wheels look vertical when seen from behind?
If they look like /-------\ or \-------/  then it sounds like a axle replacement.
No camber just bushings they are on top of axle between axle and body
Wheel nuts
Today 10:16 AM
A Testing Question....
Today 09:59 AM
Yesterday 04:31 PM
Yesterday 11:13 AM
Last Post: JPCoetzee
15-03-2026 10:34 AM
13-03-2026 03:21 PM
12-03-2026 03:52 PM
OIL Drip
12-03-2026 01:49 PM
10-03-2026 10:47 PM
10-03-2026 02:49 PM
