Threads: 3
26-04-2016, 08:37 AM
(This post was last modified: 26-04-2016, 08:41 AM by Minewash.)
Dear Friends,
The clutch cable in my Berlingo 1.6 HDI 2008 car broke down a month ago, and a new original cable was fixed instead. After fixing the new cable the clutch pedal became easier.
Just after a month or so from fixing the new clutch cable, I started facing problems with the gear. Sometimes the clutch pedal needs to be pressed again and again in order to to put it in 1st gear, or change from 1st gear to 2nd, the most difficult is putting it in the reverse gear!
I have been told the the clutch cable needs adjustment, is that correct? Any advice please.
Thanks a million.
Threads: 43
Thanks Received: 414 in 371 posts
Thanks Given: 137
33
It should have an automatic adjuster built into the cable . it gets adjusted when cable is fitted.
As its a new cable I would think the problem is in the clutch itself , possibly the cause of the original clutch cable failing.
The release bearing is known for sticking on its shaft , wears the clutch pressure plate and gives trouble selecting gears .
If so gearbox out jobbie.
Threads: 3
Thank you very much Brodfather. I understand that I need to get the clutch itself checked by a mechanic, as its mostly something with the clutch itself, thank you.
But, I still have a silly question, apologies for that: What do you mean by saying "If so gearbox out jobbie"?
Big Thanks
Thanks Received: 69 in 66 posts
Thanks Given: 8
5
Gearbox out to fit clutch.it's self adjusting cable on the pedal. So sounds like new clutch needed
Threads: 3
Hi All,
This morning and while I was driving with my Berlingo, and when I wanted to change from higher gear to lower (4th to third), and when I pressed the clutch pedal I heard a clear noise and lost the pedal, the car was in gear and not clutch as I lost the pedal. i had to stop the car, turn the engine of and start driving again. On the way back from work, I got the car checked at a specialized garage. The mechanic said that the clutch is perfect, and the clutch cable was not fixed in the right way, and he fixed it.
While driving back home, same thing happened to me three times where I had to stop and turn the engine of in order to start driving again. I drive 22 km each way, short distance!
I called another good mechanic, and he said that the cable is faulty, I am taking it to the garage tomorrow morning! Does anyone have any idea?
Thanks in advance!
