26-04-2016, 02:02 PM
Hey as the title suggests I have an issue where the brake lights are not working but the high level one is.
As far I can tell from the Peugeot Partner Haynes that I have access to, the circuit goes via the interior fusebox (I checked all of the fuses under the steering wheel and they were fine, are there any others inside, perhaps behind the glove box?), then via the brake switch, direct to the brake lights. The high level one isn't included on the diagram I have, but that's coming on during braking, so I can only assume the brake switch itself isn't faulty.
I've checked the bulbs are ok and I'm going to try shorting the brake switch/jamming something against the brake pedal after my lunch to see if there is voltage getting to the correct bulb. Anyone got some ideas? I've done a search and others have posted with similar issues but none have solutions posted. I'll update if I find out what the problem is. Thanks
