[Steering & Suspension] STEERING PROBLEM
hello got a bit off a strange problem with my steering on my 2003 berlingo forte
when I turn left or right my steering wheel jerks to straighten up it also has the same effect
when I'm sitting still and turn the wheel left or right it is not on full lock when this happens
but probably about 75% off wheel turn hope I've explained this problem so anyone can
understand it thanks in advance for any help Sad
from what you have said i would start by checking the fluid level - if low check for leaks
  • znapp33
Sounds like the front strut top bearings seized ?
[-] The following 1 user says Thank You to DaveH for this post:
  • znapp33
steering knuckle on bottom of column,just behind the engine where it pokes through the bulk head,reach down from drivers wing and give it a good spray with WD,do it again next day then give it a go with an oil can,cheap fix to try 1st,I'll owe you a pint if it isn't :-) exactly the problem with mine,but i spent money on the other stuff 1st so had my hands burnt...just check,it gets all the crap and the heat from the engine and starts seizing,sometimes feels ok when it's raining if you've noticed.
[Image: smokingdog-1.gif]
Berlingo First,75bhp 1.6hdi,58 plate....225k and counting.
[-] The following 1 user says Thank You to ians_lingo for this post:
  • znapp33
I would say top strut bearings too. Jack it up and give it a spray with wd40. If it's any better it will confirm it's them and they want changing
[-] The following 1 user says Thank You to Yorki for this post:
  • znapp33
(26-04-2016, 03:27 PM)polar Wrote:  from what you have said i would start by checking the fluid level - if low check for leaks
its been in garage level ok fliud bright red no leaks
(26-04-2016, 04:27 PM)ians_lingo Wrote:  steering knuckle on bottom of column,just behind the engine where it pokes through the bulk head,reach down from drivers wing and give it a good spray with WD,do it again next day then give it a go with an oil can,cheap fix to try 1st,I'll owe you a pint if it isn't :-) exactly the problem with mine,but i spent money on the other stuff  1st so had my hands burnt...just check,it gets all the crap and the heat from the engine and starts seizing,sometimes feels ok when it's raining if you've noticed.
thanks will try this tomorow as live in scotland and its snowing no garage lol
[-] The following 1 user says Thank You to znapp33 for this post:
  • ians_lingo
(26-04-2016, 04:14 PM)DaveH Wrote:  Sounds like the front strut top bearings seized ?
been checked at garage could find no problems as just got new front springs and top
plates last week
Any news sir ???
Mine is doing the same as this. I think it had been sitting for a while, it seems to be getting better with use. I shall be trying plus gas in this joint to see what happens.
Sent from my SM-G361F using Tapatalk
2006 Berlingo 2.0hdi desire daily hack
1998 Xantia Activa turbo for fun.
Last Post: ADarkDividedGem
Yesterday 10:25 AM
08-06-2026 11:13 AM
Last Post: TGD
06-06-2026 09:50 PM
Last Post: CB-K9murph
05-06-2026 05:47 AM
03-06-2026 06:47 PM
Fuel pump problems
02-06-2026 07:07 PM
Last Post: Desdinova
27-05-2026 10:15 AM
Last Post: Stevie3393
25-05-2026 12:34 PM
24-05-2026 12:57 PM
Rattling calipers
Last Post: Chrisfox1975
24-05-2026 10:47 AM
