Threads: 16
Thanks Given: 3
28-04-2016, 11:49 AM
(This post was last modified: 28-04-2016, 11:52 AM by MarcoLingo.)
Afternoon. I have the airbag light issue, which seems fairly common. It comes on with a beep then another beep seconds later. The issue 'fixed' itself for a week or so, then came back
Could someone please steer in in the right direction with the easiest options to try first. Consider me technically-challenged when answering, and please outline the steps I need to take in each possible solution. Don't assume knowledge on my part when it coma to naming components
Many thanks
Marco
Thanks Given: 188
23
First thing have you been moving the seats back and forward lately? if so check the connectors under the seats as they play up. Plenty of threads on the site if you have a search.
Are we there yet?????
Threads: 32
Thanks Given: 13
Make sure nothing is trapped or lodged under the seat. Any debris under there and mine comes on.
Try the seat in different positions while the engine is off to see if it goes out when you start her up.
Gives the connectors under the seat a squirt with WD or some GT85
Threads: 46
Thanks Received: 157 in 127 posts
Thanks Given: 34
23
There are normally two connectors under the seat [one brown, one white] one is for the seat belt warning and the other for the airbag warning system. Normally it is one of those. You can try pulling them apart and cleaning, note that electrical contact cleaner is a better choice than WD40 or such, as contact cleaner evaporates completely rather than WD40 type sprays that leave a "thin film" on the contacts which can cause problems over time.
Also make sure the wires are secure in the connectors, they are prone to pulling out due to rear passengers feet kicking them.
