location of starter motor
anybody got a picture or diagram of location of starter motor and how to take it off its a berlingo 1.9d 2005 the guy at the auto shop said there are 2 different types so was going to take it to them thanks
Sent from my SM-G920F using Tapatalk
Dont take this the wrong way mate but get a haynes manual if you are asking these kind of questions you will need one.
Yeh iv ordered one but I'm stuck as it won't be delivered for a few days so I thought I would ask for advice from a forum where people know these things to save a bit of money left. thought that's what forums like this were for bit no bother obviously not
[-] The following 1 user says Thank You to ciggy for this post:
  • Growler73
Remove the  battery terminals, follow the largest cable from the + end of the battery (It is marked +  on the battery casing). Don't get sidetracked into the engine fuse box , its a dead end . You will need to remove the engine covers and  the air cleaner pipes/ducting. At the front of the engine is the starter motor and the cable you are following is fixed to the top of the starter motor (really the solenoid which operates the motor). It is bolted in with three bolts. You may struggle to remove the rear one .
You can search on ebay for starter motors and pictures of them will give you an idea of what to look for, they are all similar looking.
 Good luck.
I'm sorry to say, but I'm with you on that one. I was stuck earlier in the week with a dead dash on mine. Didn't have manual or Haynes with me so posted on here. Don't know why I bothered. Umpteen people looked but not one reply. I'm a member on several forums and this one is the worse if them all. Just seems to be no commerardery
[-] The following 1 user says Thank You to Yorki for this post:
  • Growler73
Maybe a lot of people read them but don't reply cos they dont know?.
(30-04-2016, 08:52 PM)Johny555 Wrote:  Maybe a lot of people read them but don't reply cos they dont know?.
Indeed, there is no point in just saying 'I don't know' in reply to a query and please remember that those that may know the answer might not be on line for several days.
There are very few  'experts' on here just people trying to help.
[-] The following 1 user says Thank You to Trevor for this post:
  • Satellitemark
I find the opposite, with my Berlingo (a b9) there is no manual available, so when I've asked questions I've had helpful responses .
Can't fault the forum and am very thankful for the help received.
Mark
Sent from my BUSH 5 Android using Tapatalk
[-] The following 2 users say Thank You to Satellitemark for this post:
  • ians_lingo, pinkpanther54
(30-04-2016, 08:10 PM)Yorki Wrote:  I'm sorry to say, but I'm with you on that one. I was stuck earlier in the week with a dead dash on mine. Didn't have manual or Haynes with me so posted on here. Don't know why I bothered. Umpteen people looked but not one reply. I'm a member on several forums and this one is the worse if them all. Just seems to be no commerardery
Did you find what it was and post a fix up ? If no one knows how to fix it don't blame the forum camaraderie (that's how you spell it Wink)
  • Satellitemark
Was a fuse. Just checked them all till I found one blown. Will post which one when I get it back and identify it
Sent from my SM-G900F using Tapatalk
Today 02:22 AM
removing front strut
Today 02:07 AM
Strut Top Mounts
Yesterday 07:58 PM
14-09-2026 09:27 PM
Rear seat belt breakage
14-09-2026 04:13 PM
12-09-2026 05:49 AM
07-09-2026 09:06 AM
Last Post: BDRichardson
06-09-2026 04:07 PM
Last Post: kulat
03-09-2026 09:59 PM
29-08-2026 08:39 PM
