cutting out HDi 1.6 diesel
hello
i have a Belingo guess its a second edition as it was the first one registered in the uk as an 08 reg.
its now don't 81211 miles, but has started to stall.
its ok on a short drive between 10 and 30 miles but on a longer drive of over 125 miles it starts to stutter, it feels like its misfiring but as its a diesel this isn't possible
then when pulling to a stop the engine just stops, when trying to pull away.
initially it won't re start but after the 8th attempt it restarted.
it has now done this on 3 different journeys, twice on one journey of 175 miles and once at 150 miles and once at 125 miles.
it has been in for diagnostic tests two times but no faults are reported and no error lights or warning sounds occur when it brakes down, and no smoke is released.
we have no idea what could be causing it.
the citroen garage say they don't think its the EGR valve even though lots people have suggested this to me, or could it be a fuel injection fault ?
does anyone else ever had this problem.
many thanks
Threads: 12
Thanks Received: 69 in 55 posts
Thanks Given: 7
have you changed the fuel filter?
(29-04-2016, 06:38 PM)finny Wrote: have you changed the fuel filter?
hi.
thank you for your reply
its due a service in just under 3000 miles so i am assuming it will be done at that time.
it goes to a citroen garage alway for its services etc.
its been serviced every year, so assuming they are doing the correct filter changes.
my thoughts are its fuel related.
i might add that i have always only used supermarket fuel or esso, but the first time it broke down i had filled the car with Harvest diesel. i don't know if this is just a coincidence.
the last time i filled it up as suggested by the garage i fill it with supreme fuel and i also added an additional additive that the garage gave me, hoping it would stop the problem, but it appears that didn't work.
Threads: 20
Thanks Given: 2,126
18
Don't assume.Check your bills to make sure.If it's been missed,which is quite possible,changing it might solve your problem.
Strawberry flavoured windows
Threads: 41
Thanks Received: 405 in 362 posts
Thanks Given: 134
31
30-04-2016, 05:55 AM
(This post was last modified: 30-04-2016, 05:57 AM by brodfather11.)
Diesel engines can misfire !
injector faults ,leaking fuel pipes , valves, dirty filters and many other things can cause a misfire in a diesel engine
(30-04-2016, 05:55 AM)brodfather11 Wrote: Diesel engines can misfire !
hi
oh ok i didn't know that.
we are getting very frustrated as never know if or when its going to just stop.
now again waiting to see what the garage think it could be, but they very reluctant to actually LOOK and check things rather than just rely on what the diagnostics say.
thank for your suggestions
Threads: 29
Thanks Received: 14 in 13 posts
Thanks Given: 4
02-05-2016, 01:44 PM
(This post was last modified: 02-05-2016, 01:45 PM by Peter Palmer.)
Thought I would try and be useful being a newbie, I had a Focus with the same engine, sometimes it would run fine but when it got warm it would start to misfire and kangaroo, just like it was running out of fuel. Had it on the diagnostics and the first couple of times it didn't show a fault, then it came up with a crank sensor fault, replaced that and all was well.
I dont even think the sensor was faulty, the wiring to it was very tight and I think it was a bad connection but for a £15 part its worth a try for a quick fix.
BTW the crank sensor was just behind the front aux belt pulley, not the gearbox end, I presume the berlingo is in the same place.
(02-05-2016, 01:44 PM)Peter Palmer Wrote: Thought I would try and be useful being a newbie, I had a Focus with the same engine, sometimes it would run fine but when it got warm it would start to misfire and kangaroo, just like it was running out of fuel. Had it on the diagnostics and the first couple of times it didn't show a fault, then it came up with a crank sensor fault, replaced that and all was well.
Thanks for that all info is useful, lots of suggestions for me to throw at the 'Professionals" .
Its seems to me that the mechanics now days rely on what the diagnostics say rather than them think Mechanical problems.
Thanks again everyone.
10-05-2016, 12:37 PM
(This post was last modified: 10-05-2016, 12:39 PM by Belleisa.)
(02-05-2016, 02:24 PM)Belleisa Wrote: (02-05-2016, 01:44 PM)Peter Palmer Wrote: Thought I would try and be useful being a newbie, I had a Focus with the same engine, sometimes it would run fine but when it got warm it would start to misfire and kangaroo, just like it was running out of fuel. Had it on the diagnostics and the first couple of times it didn't show a fault, then it came up with a crank sensor fault, replaced that and all was well.
After another longish drive the car cut out again, this time after 125 miles.
i took it in again this morning to be diagnosed and at last a fault code has shown up.
it suggested the Cam shaft sensor was not working properly so they replaced it for me so with luck the car should now not cut out.
and also stop miss firing.
thank you to everyone who made suggestions as to this problem
Thermostat Overheating, Radiator Cool
Today 06:24 AM
Yesterday 06:54 AM
20-05-2025 09:42 AM
» Replies: 54
Last Post: rnamman
19-05-2025 02:03 PM
Last Post: allanr
18-05-2025 05:57 PM
Oil consumption at 200K miles
Last Post: Buki
18-05-2025 08:29 AM
Forum activity
17-05-2025 06:32 AM
Emissions fault.
11-05-2025 06:29 AM
10-05-2025 05:31 PM
Winter Tyres
10-05-2025 02:42 PM
