hi there
I have a 03 berlingo van 2.0 hdi just failed mot due to rear fog light not working I have checked bulbs there ok but cannot check fuse as I do not know which one it is ,the handbook does not mention the rear fog lamp in the fuse box ,anyone any ideas
many thanks
colin
Thanks Given: 188
23
Try F18 it should be a 5a
Are we there yet?????
Hi there
Thanks for the reply but in my handbook F18 is a 40amp fuse for the air blower,
Cheers.
Thanks Given: 188
23
They are a bit hit and miss there seem to be multiple combinations. Its going to be a low amp fuse try checking all the 5A fuses there cant be many.
Hi there again
Checked fuses all ok f18 is 40 amp larger size fuse but all fuses ok anyway so must be wiring problem any ideas anyone
Cheers
Thanks Given: 188
23
Just looked in my handbook and its not listed in there either so that's no help. Start with the basics check bulbs make sure they are correct type and they light up. You probably know this but fog only works when headlights are on. Check power going to and from the switch, check power at the light and check earths. Some have mentioned there is a junction in the wiring loom around the wheel arch area on what ever side the loom goes from front to back. Perhaps others can shed light on this for you.
