Threads: 3
Thanks Given: 1
The dashboard lights up, pre-heat and everything works, battery is good.
I try to start the engine and nothing happens, no sound, no clicks, nothing.
I tried bridging the starter solenoid but nothing, except a few sparks.
Has anyone any idea's or have I found the problem already? (The solenoid?)
For the second time this week, the van is stuck on the drive.....
Arse.
Thanks Received: 69 in 66 posts
Thanks Given: 8
5
Sounds like starter motor.
Threads: 10
Thanks Received: 8 in 8 posts
Thanks Given: 8
Old school trick. Tap the starter with a hammer while someone tries to start it
Safety warning. Don't leave it in gear or you might die
The following 1 user says Thank You to Yorki for this post:1 user says Thank You to Yorki for this post
• whitebus
Threads: 5
Thanks Received: 131 in 115 posts
Thanks Given: 3
19
01-05-2016, 10:46 AM
(This post was last modified: 01-05-2016, 10:48 AM by Col.)
Agreed, does sound like starter, but make sure battery is charged fully. A flat battery is similar
Threads: 10
Thanks Given: 8
Have you tried to bump start it
Threads: 10
Thanks Given: 8
Get a neighbour to push. Give heater plugs a couple of warms first and then bump it. Should fire up
Sent from my SM-G900F using Tapatalk
Threads: 3
Thanks Given: 1
You could tow start it!
