01-05-2016, 05:07 PM
I have very in depth knowledge of VAGCOM/VCDS diagnostics so I understand what I am doing but if I am honest the PSA software has got me a bit lost...
DiagBox is loaded and working (V7.83) under windows XP (32-bit) and I have been playing around with my 2016 Berlingo.
I have had a look at the fault journal and there are hundreds (391) of what appear random faults at various mileages from 9 miles up to the current. Oil gauge fault is a common one as well as a few other airbag/pretensioner faults which show up in the software but nothing in the vehicle itself. Is this normal? I appreciate that some faults may be generated as I scan the modules in the vehicle but even so there are loads of other unknown faults.
Also, how do you actually configure options and I give you an example. My van is used most of the time on private land for very short hops between buildings at low speed. The seatbelt warning is loud and I assume it can be turned off but I can't see how or where in the software you could do this? In VCDS it is quite straight forward to alter this option and others but the DiagBox looks a little misleading.
Now, I may have it all wrong and be trying to use the wrong tool for the job or settings like I want to change are simply not possible and if not what other software options are available?
All help appreciated.
