  • 7 Vote(s) - 2.71 Average
About once a year....
.....my Berlingo does this weird thing. At first it sounds a bit like there's a motorbike behind, gradually getting louder. If you continue, the engine loses power (I only had this happen once, the first time it did it). Now I know to pull over, turn the engine off, re-start and it's fine. I think it's putting too much fuel through (1.9 deisel, 02 style but first reg. march 03). Anyone else had this happen?
When I got it, it had been a motability car and was 3 years old, fsh,and in good order. The first time it did it, I'd only had it a couple of weeks, I didn't know what was going on (but it was under warranty so I didn't worry too much) and it was not a pleasant experience!
Ive had it happen in my mk3 berlingo a few times. Been to the dealer and couldnt find any faults.
I DO MISS MY BERLINGO Heart
(26-09-2011, 04:39 PM)philip Wrote:  Ive had it happen in my mk3 berlingo a few times. Been to the dealer and couldnt find any faults.
No, but I dare bet that the dealer charged you for diagnostic checks even if No Fault Found ???
How often is it happening? More than once a year or so? As turning the engine off seems to revert it to normal, I wouldn't expect the dealer to be able to find a fault. Only way would be if you happened to be driving past the dealership when the car was doing it!
Glad it's not just me, sort of! Sorry it's happening to you too.
They never :eek:
My Blingo is used as a taxi so mine does it almost every time im out working, it can happen any time doing 30mph or 60mph!
my 2001 1.9d dw8b does this, i believe its something to do with the electronic pump timing, turning it off and then back on resets the solenoid/relay and its ok again, i read it on a web site somewhere
Last Post: magoo1
Yesterday 06:31 PM
» Replies: 74
Last Post: Dyane6
Yesterday 05:19 PM
1.6hdi starting problem
14-10-2026 01:38 PM
12-10-2026 02:50 PM
12-10-2026 02:31 PM
12-10-2026 11:22 AM
» Replies: 76
06-10-2026 12:46 PM
06-10-2026 10:00 AM
