Thanks Received: 1 in 1 posts
02-05-2016, 08:55 AM
Hi Guys
I have been looking at some 18" C4 wheels for my XTR 2014 they are 4x108 8j et34 dors any one know if they will fit ok
Regards Neil
Threads: 12
Thanks Received: 69 in 55 posts
Thanks Given: 7
the 18s in my pic are of a c4 but I think they are et 27, what wheels are you fitting?
Threads: 12
Thanks Given: 7
225/40/18 xl 7j wide et 25, I have also run 225/40/18 7.5j et 18, but yours at et 34 are going to be closer to the inside space, ive not seen them on a berlingo before
Has anyone experienced ESP / ABS faults on a Berlingo by fitting larger wheels I rang today to purchase some tyres and was told that it would make my car illegal fitting 18" wheels and it would fail the MOT is this correct?
Regards Neil
Threads: 27
Thanks Given: 20
13
I guess the question is what are you hoping to gain by changing to 18"
09-05-2016, 08:57 PM
(This post was last modified: 11-05-2016, 07:21 AM by Neil Wildman.)
Ok Guys
I have got to the bottom of things
What the un knowledgeable miss informed tyre salesman was trying to say was my vehicle uses TPMS
Tyre pressure montoring system !!!
He belived the sensors in the wheels were used for the stability control system!!!!!
And changing the wheels would upset tge ecu and it would randomly apply my brakes at high speed and subsequently i would have to have the car re programmed to suit!!!!!
Im an engineerr and was sceptical of his recommendation and advice so ive done some research.
Citroen do not use the TPMS sensors for anything other than tyre pressures it is a Direct TPMS so does not affect the stability control you just have to buy some alloy adapter valves so you can swap your sensors.
The system he is confused with is indirect TPMS which is fitted to BMWs and a lot of other German vehicles that uses the abs system to keep an eye on the rolling radius and as the tyre deflates it seses a reduced diameter of the tyre thease systems do need to be re callibrated when you fit different wheels and are very sensative to change.
Neil
Thanks for posting your update. Handy to know.
The following 1 user says Thank You to Stu999 for this post:1 user says Thank You to Stu999 for this post
• dumdum
