02-05-2016, 11:20 AM
Hi Folks,
I'm interested in modifying at least the two rear most internal lights so that I can run them from another battery, also avoiding the problem of the engine battery timeout.
Does anyone have any wiring diagrams, wiring layouts, or even pictures of the wiring layout of the roof lights? I also have the slight complication of having the modulo roof with fan, I'm not sure if they share the same bus and fuse?
My plan is to use a voltage detector relay (part of my tow bar electrics, for switched charging indicator to the 13pin socket) as a means to switch the lights to an alternative battery supply. I will take the output from the voltage detector relay to operate another relay that will hopefully switch the permanent supply to the roof lights away from the vehicle battery to the aux battery.
Any, info would be gratefully appreciated, especially any diagrams and pics.
Will let you know how I get on in due course.
Cheers!
Colin.
Cheers!
Colin.
Citroen Berlingo XTR (2016)
- Modulo Top / Climate Control / Auto Pack / Airbags / Sensors & Camera
- Amdro Bootjump (camper conversion)
