Threads: 8
Thanks Received: 8 in 7 posts
Thanks Given: 2
Hi All
Just wanted to canvas for opinion on the Berlingo air con. From new, mine has been cool, but not cold. It hasn't got worse but just wondered if others have experienced the same? Maybe the Berlingo air con is just not that great, or maybe mine didn't have enough gas from the factory? Just wondered before I go and get it topped up.
Mine is 18 months old.
Got a nice little trip to Italy coming up in the bingo, and want it nice and chilly!
Threads: 52
Thanks Given: 87
5
All I can say about mine is that it does keep the interior "comfortable" on a hot day. It's not the an arctic gale like I've had on some cars but I find it adequate, especially when I have it just cooling the cabin air (outside intake turned off). That's subjective to be sure but it is tough to be quantitative.
Threads: 9
Thanks Received: 26 in 21 posts
Thanks Given: 19
My M59 aircon works ace, it's still blowing very cold 6 years after I bought the car!
Threads: 20
Thanks Given: 7
15
Mines freezing - but then even with the heating up full chat in the winter it's still freezing!
Threads: 27
Thanks Given: 20
13
I've had the system topped up once over the last eight years, it's cold enough considering the large volume of the car and brilliant at demisting when needed.
It's far better then a draughty open window.
Threads: 20
Thanks Given: 2,126
18
My M59 was colder than my new B9.
Strawberry flavoured windows
Threads: 0
Thanks Received: 14 in 13 posts
05-05-2016, 12:56 AM
(This post was last modified: 05-05-2016, 12:57 AM by robfitzi.)
A lot of vehicles come with insulation covering the suction (cold larger pipe) under the hood and a lot don't . if you insulate this pipe you will increase your a/c efficiency by reducing the load on the system.it will also improve fuel economy by reducing the refrigerant head pressure,less refrigerant leaks, cools down quicker.Make sure to cover the pipe properly ,no splits or gaps to prevent condensation forming on the pipe under the insulation. Only the aluminum pipe is to be covered up to the flexible rubber hose.The high side pipe (hotter thin one)don't cover.
Threads: 8
Thanks Given: 2
Thanks for all your replies, sounds like mine is probably normal then but will try a regas, I'll post how it goes.
Good warning on the diy regas, I saw that and thought it was too good to be true, I'll give it a wide berth!
Threads: 6
Thanks Received: 7 in 4 posts
Thanks Given: 3
I just had a free check Air con test Pom my 10 plate XTR at my local Halfords Autocare centre and they said it was 12 degrees. So I got new Re-gas and now works a treat, yesterday I had to turn it off as it was that too cold, they say you should have a re-gass ever two years. When I put my own thermometer it read 2 degrees.
PS: I not a big Halfords fan but I give the staff 10 out of 10 for this job.
2010 Citroen Berlingo Multispace XTR 1.6HDi in blue
