What upgrades have you done to your Berlingo?
I'm thinking of going from 243mm front brakes, to 266mm (I think my 283mm's may be overkill for a 1.9D Big Grin )
A working stereo and some speakers (OEM one is there but I don't have the code)
and fitting my 306 wheels as they are 185 insted of 175 lol
Andy
Hi Andy,
I don't think you need a code for the OEM stereo, I think you will need to have it mated to the car via lexia.
Mark
Mine is 1.9D Converted to an XUD9TE running at around 30psi of boost - fueling upped to match, 306 GTi6 front brakes (whatever size they are!), 15 inch 306 alloys.
I'll be attacking the rear beam to lower it a little at some point too, as well as fitting a front mount intercooler when i can find the correct inlet manifold!
Today 06:32 AM
Clocks dropping out
Last Post: Micklew
Yesterday 09:29 PM
air con
Last Post: magoo1
Yesterday 04:56 PM
triangle light
Last Post: Buki
Yesterday 08:44 AM
16-07-2026 03:29 PM
Last Post: Triggermann
16-07-2026 01:47 PM
15-07-2026 12:17 PM
14-07-2026 01:49 PM
13-07-2026 10:07 PM
11-07-2026 12:02 PM
