Berlingo v Partner
Hello
I currently own a 09 plate XTR, which has never let us down, apart from the suspension rattle!
We are looking to change it and are looking at a Skoda Yeti and a newer Peugeot (62 plate) Partner, the question I have is-Does the Partner suffer the same suspension problems of the Berlingo?
I'd prefer to stick with the Partner/Berlingo style but don't want the disappointment of owning such a practical vehicle whilst listening to the suspension knocking!
Mike
They are the same car, the suspension rattle is not a standard feature, my 08 doesn't have it and it has 107,000 miles under its belt.
Mark
[-] The following 1 user says Thank You to Satellitemark for this post:
  • Mike Hassam
They are the same car AFAIK. Just different badge. They come off the same assembly line. A number of videos on youtube showing the assembly line with a mix of Partners and Berlingos following each other. Löwen here Hasenzähne there. All with the same warts.
[-] The following 1 user says Thank You to 3rensho for this post:
  • Mike Hassam
Thanks for the replies, we're going to see the Partner on Tuesday so will see how it goes.
My 12 plate XTR has never had problems with the suspension.
[-] The following 1 user says Thank You to Trevor for this post:
  • Mike Hassam
They need a bit of weight in them to ride nicely. Mine is a bit clunky and skittish when completely empty but rides very smooth with the welder and a load of steel on board.
[-] The following 1 user says Thank You to Solent for this post:
  • Mike Hassam
Talking about the differences between the Peugeot Partner and the Citroen Berlingo, is like trying to decide between the Austin Mini or the Morris Mini!!! Same vehicle, different badges ffs. There are plenty of Peugeot Lions to be found on the components making up my Citroen Berlingo! I'm on my second B9 Berlingo and have never had this suspension rattle that many moan about on here... maybe I've been lucky!
[-] The following 1 user says Thank You to CourierJim for this post:
  • Mike Hassam
Point taken about the suspension rattle, I moved from a 53 plate to a 09 and the suspension knocking was a huge disappointment. Partner/Berlingo-either or-I'd have another one in an instant, I think its a case of 'once bitten..'
I'm not sure why the suspension rattle is I big thing, that sort of thing can usually be rectified by a decent indi garage for around £100.
Mark
(08-05-2016, 05:08 PM)Solent Wrote:  They need a bit of weight in them to ride nicely. Mine is a bit clunky and skittish when completely empty but rides very smooth with the welder and a load of steel on board.
But i don't want the misses in the Berlingo all the time Sad bit like the Berlingo she rattle's on. Rolleyes
Rattling calipers
Last Post: Chrisfox1975
Yesterday 08:09 AM
eolys
Last Post: magoo1
15-05-2026 06:02 PM
Yet another ABS fault
13-05-2026 05:57 PM
Mileage
Last Post: Taffy747
11-05-2026 11:51 AM
11-05-2026 09:17 AM
03-05-2026 01:27 PM
Head unit quad lock
03-05-2026 11:17 AM
Spare Key Fob?
29-04-2026 08:05 PM
29-04-2026 06:27 PM
Eolys problem
24-04-2026 07:07 PM
