08-05-2016, 08:43 PM
I have the standard single din Citroen CD/Radio unit in my recently acquired 2008 multispace XTR. I have noticed that when I switch off the RDS tuning on the radio, if I change stations or after I have turned the radio off and back on again, the RDS turns itself back on. Is this a fault with my specific unit or is it the way it is set up [is everybody else's radio the same?]
The reason I want to turn RDS off is that I seem to be in one of those areas where I am at the fringes of reception for various stations, so with RDS on, it tends to hunt around [or momentarily go silent while searching for a stronger signal]
I used to have the same problem on my old Berlingo M59 model but I just turned the RDS off and it stayed off...
