  • 25 Vote(s) - 2.8 Average
Wipers not working!!
I posted yesterday regarding my front wipers/washers not working. I tried everything I was advised on here but te fuse was intact. For Zsara Picasso, C3, C2, Berlingo, Partner, Picasso. By accident I typed in my problem on the net and this is what I found:
1. ignition on
2. disconnect grey 6 way plug from comm 2000
3. wait 3-5 seconds then lights come on (mine didn't)
4. switch ignition off and wait 2 minutes
5. reconnect comm grey plug
6. switch ignition on
7. switch ignition off
8. put wiper stalk in auto or intermittent position
9. put wiper switch in off position
10. allow bsi to shut down 2 minutes
11. switch ignition on
That's it!! Mine are worki ng fine now and I didn't even buy a fuse Big Grin
[-] The following 1 user says Thank You to Michele for this post:
  • john.cassidy
NOTE TO MODS:
Would you be good enough to merge this solution
into the original thread, please. Cool Ta!
Same problem, same solution, problem solved. And only two dark rainy October evenings of wrecking my head trying to find the blown fuse. Which is hard, when the fuse isn't blown.
thanks...
Can somebody tell where the comm 2000 is please?
The comms unit is the indicator/wiper module under the steering wheel. Google it and you will see an image to make it clearer.
  • bhcalcutta2
i had this the other day, pulled over, removed +ve to battery, put it back on a few seconds later, job done all working again
Leaking windscreen or aerial
Last Post: Guanajuato
Yesterday 09:05 PM
Apple Carplay
02-04-2026 01:26 PM
